Введение
Use this guide to replace the main shaft seal in a Little Beaver Augers MDL5HD 2017.
Remove the auger bit before starting this guide.
This procedure involves removing both main shaft seals, which are stacked atop one another. Make sure you have two replacement seals ready.
Выберете то, что вам нужно
Pull the spark plug connector straight off of the spark plug.
Use a 1/8 inch hex key to loosen the set screw securing the main shaft adapter.
Use a 1/4 inch hex key to remove the bolt securing the main shaft adapter to the main shaft.
Use a set of snap ring pliers to remove the snap ring over the main shaft seal.
Use a seal puller to pry out the first main shaft seal.
Remove the first main shaft seal.
Use a seal puller to pry out the second main shaft seal.
Remove the second main shaft seal.
