Введение
Use this guide to replace the throttle lever and cable in a Little Beaver Augers MDL5HD 2017.
The auger bit is removed in this guide. While not necessary, removing it will make the repair easier.
Выберете то, что вам нужно
Pull the spark plug connector straight off of the spark plug.
Use a Phillips #2 screwdriver to loosen the screw securing the throttle cable clamp.
Use a pair of needle nose pliers to lift the throttle cable out of its slot on the throttle body.
Use a pair of flush cutters to cut through the zip tie securing the throttle cable to the auger and remove it.
Repeat this step for all seven zip ties along the throttle cable.
Use needle nose pliers to bend the flared end of the rivet inward to straighten it.
Use needle nose pliers to unhook the throttle lever spring from the throttle lever.
Еще один человек закончил это руководство.
