Введение
Follow this guide to replace and adjust the deflector chain and cable on a Little Wonder GX270 Maximum Output blower.
Выберете то, что вам нужно
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Slide the ball at the end of the cable through the round opening in the clevis.
Remove the clevis from the deflector cable.
Use a 7/16 inch wrench to unscrew the nut securing the cable housing to the bracket.
The next two steps will show you how to remove the master link on the deflector chain.
Use a pair of pliers to unclip the master link.
Remove the master link retaining clip.
Squeeze the tabs on either side of the cable pusher with a pair of pliers and slide it through the bracket.
Remove the deflector cable.
The following steps show how to install a new deflector chain.
Note the center link on the deflector chain.
Note the middle tooth of the pivot.
Lift the deflector so that it is horizontal.
Turn the deflector knob clockwise to lock the deflector horizontally in the wide-open position.
Use an open-ended wrench to tighten the 7/16 inch bolt until the cable is taught.
Use the lever to open and close the deflector to check that cable is properly adjusted.
Repeat step 17, then step 22 but give the nut an additional clockwise turn.
Repeat steps 23–24.
Repeat step 17, then step 22 but give the nut an addition counterclockwise turn.
Repeat steps 23–24.
Use an open-ended wrench to tighten the other 7/16 inch bolt on the cable housing until it is snug against the bracket.
Slide the rubber boot back onto the end of the cable housing.
Install the cotter pin onto the clevis pin.
