Инструменты
Запчасти
Na parte inferior da WebCam, remova os adesivos nos dois lados
Remova os quatro parafusos Philips.
Pressione nos buracos, para destravar as tampas laterais.
The screw may be easily removed with appropriate screwdriver.
The dimensions must be match! PH1 I think…
Comprei 3 kits de chaves e nenhuma tirou esse bendito parafuso, amanhã levarei a camera junto na hora da compra
Renanzinho, se usou a chave incorreta pode ser que tenha danificado a cabeça do parafuso. Para mim, foi super fácil a remoção desses parafusos. Use a chave tipo PH1.
Removing the side covers was the most difficult part of this procedure. The covers did not want to release so it took a lot of prying with a small screwdriver to get them to release. The side opposite the hole were stuck and it took quite a bit of force to get that side released. Logitech should have had release holes on both sides of the covers.
Don , did you press the holes to unlock the side covers?
Após retirar as tampas laterais, solte todos os oito parafusos Philips.
The inner four of these screws can sometimes be extremely tight. They will easily strip if you are unable to get them to turn. I had one screw that I was unable to remove so I had to break that screw fixture on the clear plastic cover. Once you can remove the clear plastic you no longer need to worry about these screws. If they are stuck they will just stay in the black plastic support as they only hold down the clear plastic.
Use the correct screw driver. So easy to unscrew.
These screws are a different size to the ones in step 2.
Yes, that is correct.
The strength of a thousand locomotives will not allow you to remove the side covers even if unclipped. Be prepared to break either the side covers or your fingers.
Michal, of course, you must gently unlatch the side covers to remove them!
For me, it was easy…
Jose:
I am 6 foot 3 with large strong hands to match. In the end, it took channel locks gripping the correct screwdriver to get the leverage to make the first few turns.
The next time I get a flat, I would like to call on you to lift the care while I change the wheel.
For those who come after us, prepare to use deadly force on these four small screws.
Robert
Robert McCullough,
“Give me a place to stand and with a lever I will move the whole world. “
Archimedes
My camera is working so the only thing I wanted to do was to get to the lens itself to see if cleaning it would correct the washed-out image I am seeing. So, to release only the main front glass cover on the camera you only need to remove the four inside screws. That will give you access to the lens itself for cleaning, if necessary. However, I now can see that the lens itself on my camera is not clear. It looks kind of milky. Wiping it does not change the milkiness of the lens. So, it look like there is nothing I can do to correct the issue. I have two of these cameras that have the same milkiness on the lens. I’m guessing it’s time to get two new cameras although I hate to have to spend $$$$ to replace them…
Remova a tampa cristalina da lente.
Remova os cinco parafusos Philips do suporte de metal.
Remova as borrachas dos dois microfones (uma de cada lado).
Don’t forget to remove the screw just below the camera lens as well.
You must do this at previous step.
Unfortunately you skipped mentioning it in the previous step when removing the 4 metal bracket support screws.
Cuidadosamente remova a base do suporte de plástico. Solte os três parafusos que prendem o circuito eletrônico.
The directions forgot to mention to remove the screw directly below the lens before this step.
Max, you skipped step 4 where I inform you of the need to remove that screw bellow the lens.
Desconecte o conector do cabo USB.
Is it a PH 1.25 or PH 2.0 connector? thanks.
Solte o clip que prende o suporte do cabo. Puxe esse suporte do cabo para fora da câmera.
Imagens frontal e traseira da placa de circuito eletrônico da webcam.
Does anyone know of any place to purchase a replacement lens assembly for the C920 HD camera? My lens has been damaged by solar UV rays and is all cloudy which deteriorates the quality of my images. It looks like replacement of the lens assembly would be relatively easy as I can only see two screws holding it in place. However unfortunately, the image shown for the backside of the pc board has a piece of paper covering the area where lens may have some connections so it.
The lens is easily removed without taking anything apart other than the two side panels and the clear glass cover piece and then very carefully turning in CCW (counter clock-wise). I would suggest using a pair of small tweezers and gently rotating the lens. Try not to move the lens around too much or you will damage the focusing mechanism. Now, I need to find a resource where I can purchase a replacement lens.
O problema da webcam era o cabo partido, na parte traseira da câmera. Cortei a parte com defeito e refiz as ligações com solda e isolei com tubos (espaguetes) termorretráteis.
Is the silver one the shield of usb cable or something else?
The aluminum foil is also a shield.
How did you find the break, or did you just assume and replace most of the cable with a spare?
Usually the cable breaks where it can be bent. I cut a piece of the cable near the device and did the continuity tests with a multimeter, to prove that the cable was ok at that point.
O cabo recuperado foi montado na câmera. Revesti-o com uma fita crepe. Câmera testada: OK !
Remonte a câmera seguindo o procedimento na ordem inversa.
Para remontagem de seu dispositivo, siga estas instruções na ordem inversa.
28 участников успешно повторили данное руководство.
Комментариев: 26
Excellent! Helped me figure out how to get the base off to mount it to an ikea worklamp as a hacky boom.
Can you post a guide or technique of the process?
Or share some photos? (On meta.ifixit.com)
Cory,
I did not understand your question.
This repair guide contains several photos.
thanks for an excellent guide . I am now more positive that it is something I can perform now. Many thanks
im having trouble releasing the 4 screws on step 3!!! the screw driver keeps slipping and i’ve tried a few and another webcam…
Dojo, Use the correct screw driver. So easy to unscrew.
If you have damaged the screw head, you can use pliers. You will need to replace the damaged screws.
They’re quite tight screws on the ones I’ve worked on . Super, super soft metal too, very easy to strip out.
All of the screws used in this camera for the two side covers and the main cover glass (steps 1 through 3) can be loosened with a Phillips #0 screw driver. I don’t know about the other internal screws as I haven’t gone that far in the process. Mine were not super tight so they came out quite easily.
Don -
Many thanks for this excellent guide!! Helped me to repair my camera
Not all the webcams are as quality as Logitech HD Pro Webcam c920. Because this is rich its specifications and full of features. Ordinary or the built-in webcams are just ways of calling at high definition resolution with low framerate.
Suddenly c920 stopped working..i thought wire is broken..but after opening up..no broken wire is visible..what must be the problem and how to solve?..pls help
Pankaj, you must measure continuity of wires of cable with multimeter.
In my case, I was replacing the damaged cable with a new cable I ordered from eBay. That requires de-soldering the black wire on the PCB and soldering the new one in place. Those who venture into that task should know that (a) the solder tab on the replacement cable is extremely delicate, so it is important to fully remove the old solder with a solder-sucker to put the tab in place, and (b) the newly-soldered wire must be oriented parallel to the camera, because otherwise, it will mechanically interfere with re-assembly. Great guide though! THANKS!
Thanks for taking the time to document this procedure. Great instructions!!
Can the crystal cover be separated? Mine shipped with dirt in between the layers
Response from someone else:
Hi Quentim,
I Think the crystal cover is glued.
Hi Quentim,
For years i’d been listening to salesmen in stores like Best Buy who told me that webcams are made to be replaced; not repaired. Thank you so much for enlightening me and saving me the $150 that Amazon wants for a C922. I repaired my C920 and it works like the day i bought it! It didn’t cost me a penny. Thank YOU!
Thanks for your work on this guide Jose, much appreciated.
Seems the cables in these commonly break near where the cable joins the body.
Is it possible to rotate the camera lens module 90’? I’m trying to mount the camera vertically, but still have the picture come out in the normal orientation. I realize I could rotate the image in the software, but this tends to skew the aspect ratio.
Great Article! Saved me $$$.
I had to solve my issue where my webcam would constantly lose focus. Thanks to this guide for disassembly i got the issue fixed in no time. Beats having to pay for another cam.
This disassembly instruction also works for the Logitech C930e
Valeu amigo! Meu gato mastigou quase todo o cabo dessa câmera, criando curto circuito desativando todos os outros dispositivos USB conectados no PC. Ainda bem que tudo voutou a funcionar ao desconectar a câmera... (não sei como não queimou a placa mãe :p), então precisava trocar todo o cabo pelo menos com outro USB que não uso mais, e quase cheguei a quebrar a tampa superioir pensando que era tudo lacrado com travas sem parafusos, mas os parafusos estavam lá né, escondidos abaixo daquelas borrachinhas...hehe
Belo tutorial, consegui soldar tudo direitinho perto do conector (já que era a única parte que não estava danificada) quase igual ao que você mostrou aqui usando tubinhos e tudo e agora tá tudo funcionando sem problemas. Obrigado mesmo! : )
The disassembly guide is great; I agree that soldering the ground cable on a replacement cable (from Amazon) requires care, to heat and remove the old cable, remove the old solder with a solder sucker, and/or desoldering copper mesh. Be careful because the circuit board lands are on top and bottom of the board. A circuit board vise is a big help.
PUT THE CABLE THROUGH THE HOLE IN THE BODY BEFORE YOU SOLDER!
There are three or four types/sizes of screws. I wish I would have documented what I took out as I went along. I was able to reassemble by guesswork. Everything is a tad loose. If I did it again, I would tape each group to a piece of paper and label as you go along.
You need a professional technician's screwdriver "0" or you will have problems.
You may find the cable, $11.95, soldering and desoldering gear $13-$20 for hobbyist grade, circuit board vise or equivalent, and professional screwdriver are about equal to the cost of a replacement camera. But then, you would not have learned anything or had fun.
If you remove the rubber stickers and don’t see any screws underneath, it’s because there are actually two layers of stickers. The top sticker is the rubber that you can see, and underneath it is a plastic sticker. Sometimes they come away together, sometimes you will need to pry away the plastic sticker after first removing the rubber.
drspod - Ответить
Existem dois adesivos em ambos os lados.
Jose Gustavo Abreu Murta - Ответить
You can heat the stickers with a lighter , so they come off very easy .
kar bouter - Ответить
