Введение
This guide will pick up from the pre requisite guide Disassembling Logitech G27 Steering Wheel. In this guide we will be showing how to replace the motors that create force feedback in-game. After following this guide your Logitech G27 Steering Wheel should be fully functional.
Выберете то, что вам нужно
Remove the six gray 25mm hex screws with a 4mm allen wrench.
Carefully lift up the wheel, but do not disconnect it from the rest of the device.
Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
Remove the wheel hub and push the connector through the center of the hub.
The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
The housing cover can be set aside until you put the wheel back together.
Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
Unplug the three plastic connectors on the left side of the PCB board.
Unplug the two plastic connectors on the top of the PCB board.
Unplug the three plastic connectors on the right side of the PCB board.
Remove the PCB board after all of the plastic connectors are disconnected.
You can now set it aside.
Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
Remove the PCB board mount and remove the clear plastic piece underneath.
Set them aside until you reassemble the wheel.
Remove the four 12.2mm screws using the Phillips screw driver.
The motors and gear box should now slide out. As you take it out, the metal spring band as well as the track for the wheel gear will also slide off.
When you have separated these parts, you can set them aside until reassembly.
Next remove the eight 15.8mm screws that connect the plate holding the motors to the gear box.
Remove the six 7.4mm screws that attach the motors to the motor plate and slide the motors off the motor plate.
The motor plate can be set aside and the motors can now be replaced.
18 участников успешно повторили данное руководство.
7 Комментариев
If you do not feel confident doing this yourself, here is a link to a company that could do it for you http://www.mz-simulators.co.uk/services....
Where can i buy this motors ?
i found 1 of each
going to buy the encoder as well and start with it and then motors if needed
