Logitech G27 Pedal Spring Replacement
Выберете то, что вам нужно
  1. Logitech G27 Pedal Spring Replacement, Pedal Spring: шаг 1, изображение 1 из 1
    • Remove two screws from each pedal with a 2.5mm allen wrench.
    • The left two pedals have 30 mm screws and the right-most pedal has 16.3 mm screws.
    • Once these screws are off, take off the front faces on each pedal, they should be very easy to remove.
  2. Logitech G27 Pedal Spring Replacement: шаг 2, изображение 1 из 2 Logitech G27 Pedal Spring Replacement: шаг 2, изображение 2 из 2
    • Flip over the device. Now remove fourteen 15.8 mm screws from the underside of the pedal assembly with a Phillips #1 screwdriver.
    • There are two of these screws under the carpet grip, make sure you don't miss those!
    • When finished, flip over the device again so that it's in its original position.
  3. Logitech G27 Pedal Spring Replacement: шаг 3, изображение 1 из 3 Logitech G27 Pedal Spring Replacement: шаг 3, изображение 2 из 3 Logitech G27 Pedal Spring Replacement: шаг 3, изображение 3 из 3
    • Lift the top cover of the device from the front, don't completely remove it yet though, because there are still wires connecting both halves. (NEED PICTURE)
    • Behind the left-most pedal, there are two 7.4mm screws attaching a wire to the top cover. Remove these with a Phillips #1 screwdriver and release the wires.
    • Once the wires are no longer connected to the top cover, remove the cover completely.
  4. Logitech G27 Pedal Spring Replacement: шаг 4, изображение 1 из 2 Logitech G27 Pedal Spring Replacement: шаг 4, изображение 2 из 2
    • Simultaneously remove the 10mm screws connecting the pedal to the red piston behind it.
    • This will take two 2.5mm allen wrenches, one for each side of the screw.
    • Once removed, the piston can rotate free of the pedal.
  5. Logitech G27 Pedal Spring Replacement: шаг 5, изображение 1 из 1
    • Flip the piston away from the pedal and remove the top half of it. The spring should now be visible. (NEED PICTURE)
    • Take out the spring, and replace it with a new one.
    • Repeat steps four and five for each pedal that needs a spring replaced.
Заключение
9 человек успешно провели ремонт по этому руководству.
Grant Blake
Участник с: 04/21/15
1 688 Репутация
Автор 2 руководств
Команду
Cal Poly, Team 15-4, Amido Spring 2015 Участник Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 членов
Автор 25 руководств
6 Комментариев
Is it possible to replace / renew the potentiometers used for gas / brake?
Dave Pawson - Ответить
I replaced the springs and reassembled in reverse order. However, my wheel will no longer power on. Any idea where I would have lost power? Thank you.
matthew.liam.gleason - Ответить
What size is the cluch spring
isaacjohnson138 - Ответить
6cm length
2cm diameter
hermimaier -
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 4
За последние 7 дней: 32
За последние 30 дней: 79
За всё время: 21,161
