Введение
We disassemble the mouse to get to the connector cable for replacement with a brand new cable.
Выберете то, что вам нужно
It's very common for this cord to fray with continued use. Let's open up this mouse and replace the cord!
Locate the hidden screw hole behind the Logitech sticker.
Puncture the sticker to access the screw.
Remove all five Phillips screws.
Using a spudger, lift the ZIF cable guard.
Remove the cable from the upper housing. The upper housing can now be set aside.
Remove the three Phillips screws to free the weight cartridge holder.
Lift the weight cartridge holder from the body.
Pry the pin securing the mouse wheel and housing to the left.
Remove the mouse wheel and housing.
Remove the two parallel screws holding a black piece of plastic to the mouse body.
Remove two screws securing the bottom circuit board to the bottom plate of the mouse.
Remove the final two Phillips screws near the top of the mouse holding the circuit boards to the plate.
Pull the circuit boards loose from the bottom plate.
You may need to use a spudger to pry the circuit free.
30 человек успешно провели ремонт по этому руководству.
15 Комментарии к руководству
Thanks for the guide! Despite being super careful with the springs they managed to flick out when I was screwing the circuit board back in, one was never to be seen again. Thankfully the middle mouse button seems to work fine with just one!
