Введение
This guide shows how to replace the mouse cable for the Logitech G502 Proteus Core gaming mouse, whether it's due to a broken cable or to swap to a better paracord. It should be a relatively easy and quick repair and doesn't require any previous experience of fixing mice. Unplug your mouse before starting this repair.
Выберете то, что вам нужно
Pull out the pin and remove the scroll wheel assembly.
Take out the two springs under the scroll wheel assembly.
Open the tabs lock on each side so you can disconnect the ribbon.
Disconnect the PCB from the mouse cable.
7 участников успешно повторили данное руководство.
2 Комментариев
Let's say you're trying to fix your G502 without a legit logitech cord, you can just splice a usb cable and solder the correct wires to the pins. I did this twice and it works flawlessly
If you are careful enough, you don't need to remove the side button ribbon.
