Введение
Use this guide to replace the lights of your Logitech G910.
Выберете то, что вам нужно
Flip the keyboard and unscrew the 15 back screws. The screws in the palm rest must be unscrewed and the palm rest removed to access the 6 screws at the bottom of the keyboard. (There are 2 lengths of screws the shorter ones are for the palm rest) There are also 2 screws under the nonslip pads of the palm rest.
Release the front part using a spudger or flat screwdriver to gently pry. Lift off carefully.
5 участников успешно повторили данное руководство.
3 Комментариев
So what do I do after I take apart my keyboard?
this guide is currently missing some steps. If you have figured it out, pls edit this guide.
tayola -
Desolder and replace LEDs the size of a grain of sand xD
This is definitely not a job I'd mark as "easy".
