Logitech Harmony 1100 Logic Board Replacement
Выберете то, что вам нужно
  1. Logitech Harmony 1100 Logic Board Replacement, How to Open Logitech Harmony 1100: шаг 1, изображение 1 из 2 Logitech Harmony 1100 Logic Board Replacement, How to Open Logitech Harmony 1100: шаг 1, изображение 2 из 2
    • Remove battery cover, pushing down on circled areas and pushing outward
    • Remove battery by lifting up on corner exposed by indent in case
  2. Logitech Harmony 1100 Logic Board Replacement: шаг 2, изображение 1 из 1
    • Use a J0 screwdriver head
    • Remove 3 screws from battery compartment
  3. Logitech Harmony 1100 Logic Board Replacement: шаг 3, изображение 1 из 2 Logitech Harmony 1100 Logic Board Replacement: шаг 3, изображение 2 из 2
    • Open connector port on side
    • Remove screw with PH00 screwdriver head
  4. Logitech Harmony 1100 Logic Board Replacement: шаг 4, изображение 1 из 3 Logitech Harmony 1100 Logic Board Replacement: шаг 4, изображение 2 из 3 Logitech Harmony 1100 Logic Board Replacement: шаг 4, изображение 3 из 3
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • Also the plastic connector door will fall off. It will need to be put back upon reassembly.
  5. Logitech Harmony 1100 Logic Board Replacement, Screen: шаг 5, изображение 1 из 1
    • Pop out plastic screen backing on front of device.
    • Loosen screen backing by pushing back on plastic clips that are holding the black screen backing in place.
  6. Logitech Harmony 1100 Logic Board Replacement: шаг 6, изображение 1 из 2 Logitech Harmony 1100 Logic Board Replacement: шаг 6, изображение 2 из 2
    • Use PH00 Phillips head from the iFixit Tool Kit to remove 3 screws from the circuit on the back half of the device.
    • Flip over the larger circuit board to the left.
    • Use the edge of the circuit board to flip the board over.
    • The connector port in the top right corner may make removal difficult. Lift the logic board above the screw ports, and the connector port should slide out easily.
  7. Logitech Harmony 1100 Logic Board Replacement: шаг 7, изображение 1 из 2 Logitech Harmony 1100 Logic Board Replacement: шаг 7, изображение 2 из 2
    • Find the wire that attaches to the screen
    • Push dark grey bar that is used to lock the screen in place, outward from beige bar to disconnect.
    • Remove screen wire
  8. Logitech Harmony 1100 Logic Board Replacement, Logic Board: шаг 8, изображение 1 из 2 Logitech Harmony 1100 Logic Board Replacement, Logic Board: шаг 8, изображение 2 из 2
    • Push grey bar away from the beige bar
    • Remove button tab wire from logic board
  9. Logitech Harmony 1100 Logic Board Replacement: шаг 9, изображение 1 из 3 Logitech Harmony 1100 Logic Board Replacement: шаг 9, изображение 2 из 3 Logitech Harmony 1100 Logic Board Replacement: шаг 9, изображение 3 из 3
    • Lift on back of gold tab to unsecure positive and negative wires from device
    • Pull the gold buttons in towards the center of the device to detach logic board from case
Финишная черта
Chris Slack
Участник с: 02/11/16
10 Репутация
1 руководство автора
Команда
Ohio State, Team 1-5, Burgess Spring 2016 Участник Ohio State, Team 1-5, Burgess Spring 2016
OSU-BURGESS-S16S1G5
4 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 866
