Введение
If the battery to the remote is not working properly, follow this guide to replace it.
Выберете то, что вам нужно
Use the Opening Tool to open the port cover at the bottom of the remote control.
Bend the cover back to gain easy access to the screws.
Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
Pull the bottom cover off of the remote control.
Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
Use the Opening Tool to lift the battery out of the case.
Gently pull the cable out of the socket to unplug the battery.
10 человек успешно провели ремонт по этому руководству.
3 Комментарии к руководству
|Just checked, and batteries are available on Amazon from several vendors. Mine is on its last legs, so I have ordered one.
