Введение
This guide will involve using basic tools to replace the case of the Logitech Harmony 950.
Выберете то, что вам нужно
Use the Opening Tool to open the port cover at the bottom of the remote control.
Bend the cover back to gain easy access to the screws.
Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
Pull the bottom cover off of the remote control.
Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
Use the Opening Tool to lift the battery out of the case.
Gently pull the cable out of the socket to unplug the battery.
Use the Phillips #1 screwdriver to remove the (3) three 6mm screws.
Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
Инструмент, используемый на этом этапе:Tweezers$3.99
Use the angled Tweezers to carefully pull the white cable end off of the remote and disconnect it.
Use the Phillips #0 screwdriver to remove the (5) five 6mm screws. Keep in mind that once the screws are off, the circuit board will be completely separate from the case.
Remove the black tape to fully access the cable underneath.
This cable has a locking mechanism. Use the Angled Tweezers to lift the black part (lock).
Slide the yellow cable to disconnect it from the circuit board.
Pull the circuit board off of the case. Start from the bottom, and lift up to completely detach it from the cover.
Use the Blunt Tweezers to carefully remove the keypad from the cover of the remote.
3 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
where can this casing be purchased?
Parts are required obviously!!
Is the usb bottom cap part of the replacement case? If not can u get one?
