Введение
Follow this guide if you are preparing to replace or clean your Logitech Harmony Touch's buttons.
The buttons on the remote controller have essential functions to the user's entertainment system, including the on/off, volume control, menu, and more controls that need the buttons to function.
The Logitech Harmony Touch User Manual provides a full breakdown of each button and its location on the controller if a button goes missing or you want a clear image of the remote after the teardown.
Выберете то, что вам нужно
Open the latch that accesses the charging port.
Remove the black sticker and the screw with the Phillips #0 Screwdriver.
Take the plastic opening tool and run it down the side of the remote to open the case.
Detach the white clamp to disconnect the case from the motherboard partially.
Peel back the thin yellow plastic film.
Detach the clip found underneath the film.
Remove the screws that connect the motherboard to the case with the Phillips #0 Screwdriver.
Next, carefully remove the motherboard from the top piece of the case.
You should now be able to access all the buttons and remove them from the case.
2 человек успешно провели ремонт по этому руководству.
