Введение
This guide will show you the process to disassemble the device and replace the motherboard.
Выберете то, что вам нужно
Open the latch that accesses the charging port
Remove the black sticker and remove the screw with the indicated screwdriver
Take the plastic opening tool and run it down the side of the remote to pop the case open
Detach the white clamp to partially disconnect the case from the motherboard
Peel back thin yellow plastic film and detach the clip found underneath
Remove the screws that connect the motherboard to the case with the suggested screwdriver
Next, carefully remove the motherboard from the top piece of the case
You should now be able to access all of the buttons and remove them from the case
