Введение
If you find that your remote control touchscreen has stopped working correctly or has been damaged, you may need to replace it in order to continue using the device. This guide will help you to access the touchscreen of the Logitech Harmony remote universal.
Выберете то, что вам нужно
Open the latch that accesses the charging port.
Remove the black sticker and remove the screw with the indicated screw driver.
Take the plastic opening tool and run it down the side of the remote to pop the case open.
Detach the white clamp to partially disconnect the case from the motherboard.
Peel back thin yellow plastic film and detach the clip found underneath.
Use a Phillips #00 to remove the screws that connect the motherboard to the case.
2 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
do you have the lcd screen P/N???
