Введение
Follow this guide to replace worn‑out or damaged rubber feet on your Logitech K540 wireless keyboard.
Выберете то, что вам нужно
Slide the power switch on the top right corner to the OFF position.
Flip your keyboard over and lay it down so the edge with the two tilt legs is closest to you.
Insert the point of a spudger under an end of the foot.
Push the spudger underneath the foot and lift until you can grip it with your fingers.
Peel the foot up and remove it.
Use your finger to push the bottom of the foot up, separating its adhesive.
Peel up and remove the foot.
