Введение
The Logitech K480 Easy-Switch dial is responsible for switching between previously paired Bluetooth devices. The dial may need to be replaced if it's been structurally compromised, such as cracked or disconnected. You also may need to replace the dial if it is missing from your device. This guide will walk you through the disassembly and removal of your Logitech K480 Easy-Switch dial.
Выберете то, что вам нужно
Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
Slide a blue pick in to keep the pieces apart while you work on other areas.
Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
Remove the eight 3 mm screws using a Phillips #00 screwdriver
Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
Remove the two black 4 mm screws from the dial motherboard located on the upper right corner of the device with the Phillips #00 screwdriver.
Pop out the Easy-Switch dial by gently pressing your finger on the underside of of the dial.
Еще один человек закончил это руководство.
1 Комментарий к руководству
Very good tutorial, it's a shame we don't know where to get the Logitech K480 Easy-Switch Dial part. Sincerely.
