Logitech M185 Wireless Mouse Disassembly
Выберете то, что вам нужно
  1. Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: шаг 1, изображение 1 из 2 Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: шаг 1, изображение 2 из 2
    • Remove battery cover by sliding it off.
  2. Logitech M185 Wireless Mouse Disassembly, Unscrew: шаг 2, изображение 1 из 2 Logitech M185 Wireless Mouse Disassembly, Unscrew: шаг 2, изображение 2 из 2
    • Unscrew the Phillips #1 screw in the battery compartment after removing the battery.
  3. Logitech M185 Wireless Mouse Disassembly, Remove the top cover: шаг 3, изображение 1 из 1
    • There is no need to remove its rubber feet since it is held together by only one screw.
    • Wiggle the grey part of the top to remove it by pulling it towards you(away from the scroll wheel).
    • Do not pull the grey cover towards the top and do not pull the part near the keys.
    • Reasoning by Jacob Hickey "because in the internal top part of the mouse where the buttons/scroll wheel is, there’s hinges-like “tooth” that’ll snap if you do pull on it. It’s like opening a jewelry box that has a hinge on one end of the box… if that makes sense…"
    • The image is what your mouse should look like in the end.
  4. Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: шаг 4, изображение 1 из 3 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: шаг 4, изображение 2 из 3 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: шаг 4, изображение 3 из 3
    • Push back small black clips to release the circuit board.
    • Slide up the metal battery connectors to free them from the casing. (Note that these are soldered to the circuit board.)
    • Fully remove the circuit board with the battery connectors and image sensor still attached.
  5. Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: шаг 5, изображение 1 из 3 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: шаг 5, изображение 2 из 3 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: шаг 5, изображение 3 из 3
    • Working from back to front (left to right in the first image) unclip the first two pairs of black plastic clips.
    • Slide the black upper casing forwards over the mouse wheel whilst applying pressure the two front clips to release them.
    • Separate the two casing layers fully.
Заключение
29 участников успешно повторили данное руководство.
Karmanyaah Malhotra
Участник с: 09/23/18
855 Репутация
1 руководство автора
9 Комментариев
Thank you Karmanyaah Malhotra for takin’ the time to do this for everybody like me :-)
Jacob Hickey - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 29
За последние 7 дней: 209
За последние 30 дней: 932
За всё время: 24,493
