Logitech M215 Motherboard Replacement
Выберете то, что вам нужно
  1. Logitech M215 Motherboard Replacement, Remove the battery cover: шаг 1, изображение 1 из 3 Logitech M215 Motherboard Replacement, Remove the battery cover: шаг 1, изображение 2 из 3 Logitech M215 Motherboard Replacement, Remove the battery cover: шаг 1, изображение 3 из 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Motherboard Replacement, Remove old battery: шаг 2, изображение 1 из 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Motherboard Replacement, Top Cover: шаг 3, изображение 1 из 2 Logitech M215 Motherboard Replacement, Top Cover: шаг 3, изображение 2 из 2
    • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
    • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
  4. Logitech M215 Motherboard Replacement: шаг 4, изображение 1 из 1
    • Pry the top cover off. You may need to use a pry tool to help.
  5. Logitech M215 Motherboard Replacement, Motherboard: шаг 5, изображение 1 из 2 Logitech M215 Motherboard Replacement, Motherboard: шаг 5, изображение 2 из 2
    • Unscrew the 0.25mm phillips head screw to release the circuit board.
Заключение
3 участников успешно повторили данное руководство.
Hannah Pate
Участник с: 01/30/15
1 734 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 1-1, Watkins Winter 2015 Участник USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 членов
Автор 28 руководств
3 Комментариев
bro whats the next step my guy
Jazmine Amaya - Ответить
Hello,
Thanks a lot for this tutorial !
Where can I buy the motherboard for this wireless mouse?
Paolo - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 27
За всё время: 5,234
