Logitech M215 Scroll Wheel Replacement
Выберете то, что вам нужно
  1. Logitech M215 Scroll Wheel Replacement, Remove the battery cover: шаг 1, изображение 1 из 3 Logitech M215 Scroll Wheel Replacement, Remove the battery cover: шаг 1, изображение 2 из 3 Logitech M215 Scroll Wheel Replacement, Remove the battery cover: шаг 1, изображение 3 из 3
    • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
    • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
    • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
  2. Logitech M215 Scroll Wheel Replacement, Remove old battery: шаг 2, изображение 1 из 1
    • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
  3. Logitech M215 Scroll Wheel Replacement, Button Plate: шаг 3, изображение 1 из 2 Logitech M215 Scroll Wheel Replacement, Button Plate: шаг 3, изображение 2 из 2
    • Use your fingernail to carefully remove the two skid stickers from the fat (non-button) end of the bottom of the mouse to reveal two Philips head screws. Remove these, then unclip the bottom cover. Don't get the sticky dusty. Now remove buttons; they're both attached by one 0.5mm Phillips head screw. It is located in the center of the top cover.
  4. Logitech M215 Scroll Wheel Replacement, Pry off buttons: шаг 4, изображение 1 из 2 Logitech M215 Scroll Wheel Replacement, Pry off buttons: шаг 4, изображение 2 из 2
    • The button are now only attached by a small overhang near the front. You will need to use the pry tool to push the button plate off of this overhang as shown.
    • The button plate should be able to be completely removed at this point.
  5. Logitech M215 Scroll Wheel Replacement, Scroll Wheel: шаг 5, изображение 1 из 1
    • Use the prying tool to remove the scroll wheel. The wheel is held in place by two pegs which stick into the plastic holder.
Заключение
9 участников успешно повторили данное руководство.
Hannah Pate
Участник с: 01/30/15
1 734 Репутация
Автор 7 руководств
Команда
USF Tampa, Team 1-1, Watkins Winter 2015 Участник USF Tampa, Team 1-1, Watkins Winter 2015
USFT-WATKINS-W15S1G1
4 членов
Автор 28 руководств
6 Комментариев
glad I was able to find this info on disassembly. Gave it a good cleaning and works better than it did before. Had the Phillips screwdriver. and used another small screwdriver and a small pocket knife to pry with. Be gentle - doesn’t look like it would take much force to break those plastic bits.
carmenanddave - Ответить
Thanks! Mouse wheel windows were blocked by lint.
levensonjb - Ответить
Very useful. Cleaned coffee out of mouse wheel spokes/windows and off of chipboard. Works better than before. Thanks!
OGrady Watson - Ответить
Probably the BROWN stuff wasn’t coffee, I too cleaned the spokes/windows. the brown stuff is oil from out hands which lands on scroll wheel, then by heat gets transferred to the spokes. touch a finger on the mirror, the fingerprint on the mirror is because of OIL on hands. it is the same oil in that mouse wheel spokes.
tejaswin_jain -
There is a spring here connected to the wheel. Seems to be the thing to give tactical feedback when scrolling. It fell out when I took out the wheel not 100% how to put it back
Dan Molnar - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 27
За последние 30 дней: 68
За всё время: 12,540
