Logitech M570 Wireless Trackball Mouse Microswitch Replacement
Выберете то, что вам нужно
  1. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Remove the screws: шаг 1, изображение 1 из 1
    • Unscrew 5 screws, which are partially hidden. Three screws are located under the rubber buffers and one in the battery compartment under the sticker (which should then be loosened beforehand).
    • You can simply push the blue trackball out of its holder. You should also do this occasionally and clean the opening.
  2. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, The Interior: шаг 2, изображение 1 из 2 Logitech M570 Wireless Trackball Mouse Microswitch Replacement, The Interior: шаг 2, изображение 2 из 2
    • After the screws are loosened, the housing can be easily removed. The space for the blue ball is made of its own piece of plastic. The circuit board is held in place with a few screws.
  3. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Detach trackball holder from circuit board: шаг 3, изображение 1 из 1
    • Lift the gray latch and pull the flat cable out of the connector. The trackball holder can then be placed to the side.
  4. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Separate the circuit board from the housing: шаг 4, изображение 1 из 2 Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Separate the circuit board from the housing: шаг 4, изображение 2 из 2
    • Unscrew four Phillips screws (orange) and lift circuit board out of housing, being careful with the wires holding the battery, but these can be lifted out of the housing without further unscrewing.
    • The switch for switching on should not be lost in the process (see second picture)
  5. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Microswitch replacement: шаг 5, изображение 1 из 1
    • Properly desolder the microswitch (green) at its three contacts
    • Solder in new microswitch, making sure that it sits flat on the board.
  6. Logitech M570 Wireless Trackball Mouse Microswitch Replacement, Reinstall the circuit board: шаг 6, изображение 1 из 1
    • Make sure that the small circuit board with the two buttons with the hole in the middle (green) is placed over the holding pin. Then it is in the correct position.
Заключение
Work through the steps in reverse order to reassemble your device.
3 человек успешно провели ремонт по этому руководству.
Особая благодарность этим переводчикам:
de en
100%
shingle помогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Peter Scholl
Участник с: 06/26/21
1 818 Репутация
Автор 7 руководств
5 Комментарии к руководству
Where I would been able to buy the microswitch?
Torpedo Javi - Ответить
I soldered it out from an old mouse... but I think you will also get it on ebay
Peter Scholl -
This guy shows replacement switches fixing a newer version of same trackball(I think). It has a built in battery now.
Replacement switches he used from ALIEXPRESS.
I think I'll try those. I've had switches lose there mechanical springy-ness and also get where they don't work reliably on 2 or 3 trackballs.
https://www.aliexpress.us/item/325680110...
https://michael.stapelberg.ch/posts/2021...
Spruce Moose Tomato Juice - Ответить
Ich konnte bei mir im Fundus eine Maus (DELL M-UVDEL1) finden, welche einen sehr ähnlichen Taster verwendet; diesen konnte ich erfolgreich verpflanzen :-)
Michael-01 - Ответить
Danke für die Rückmeldung - freut mich, wenn die Infos Menschen auf Ideen bringen bzw. weiter helfen. Viele Grüße!
Peter Scholl -
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 17
За последние 30 дней: 57
За всё время: 5,054
