Logitech M705 Teardown
Выберете то, что вам нужно
  1. Logitech M705 Teardown, Logitech M705 Teardown: шаг 1, изображение 1 из 1
    • First of all You have to remove battery
  2. Logitech M705 Teardown: шаг 2, изображение 1 из 2 Logitech M705 Teardown: шаг 2, изображение 2 из 2
    • Unscrew the screws under the label
    • Unscrew the single screw below the USB-dongle space
  3. Logitech M705 Teardown: шаг 3, изображение 1 из 1
    • Under the rubber on the top of the mouse there are other screws
  4. Logitech M705 Teardown: шаг 4, изображение 1 из 1
    • I had a problem with the right click: I solved with a shim on the little switch
    • Here we are!
Заключение
47 участников успешно повторили данное руководство.
Francesco Palmisano
Участник с: 12/02/15
1 240 Репутация
Автор 2 руководств
12 Комментариев
1) There is an additional screw that is already removed on the first picture : under the USB stick emplacement.
2) It is not necessary to remove the rubber. Just peel it with something thin, because the screws are very lateral
3) Be careful while disassembling the top, it is plugged to the base by a 3 wires connector (white/red/black on the Step 4 picture).
Philippe Puech - Ответить
Nice simple guide. I used it to quickly take apart a M705 where the laser stopped working after it fell. I didn't do more than reseat the connector cable, but it seems to work again now !
Philippe Puech's comments are good. In fact I wished I'd noticed his 2) before removing the rubber, as the lower layer distorts and doesn't fit back well on a complete removal. His comment puzzled me at first, and might be better phrased as "Peel back the rubber from each side to expose the Left and Right retaining screws. "
A screw bit labelled PH1 (Philllips Head 1) seemed to fit the screws well.
Epee Sharkey - Ответить
Hello, I recently bought used m705. but it wont turn on even if i change the battery. is there anyway i can fix this?
Thank you.
eekj97 - Ответить
Anybody knows if there's a replacement for laser sensor available?
Danyil - Ответить
great thanks.. just to clarify you screw right through the lable.. no need to remove it. that got me stuck for a while.
now
David Miller - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 18
За последние 7 дней: 85
За последние 30 дней: 310
За всё время: 35,066
