Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will walk you through the process of removing the top cover of the mouse to replace the mouse buttons.
Выберете то, что вам нужно
Hold the mouse so that the bottom is facing up.
Remove the single Phillips #1 screw from the bottom half of the mouse.
Place the mouse so that the bottom is resting against a hard surface.
Lift the top cover of the mouse gently, and remove it.
Locate the two tabs that are protruding from the button assembly.
Pinch the tabs together to free the buttons.
Remove the button assembly from the top cover by flipping the top cover upside down and pulling the button assembly downward and away from the top cover.
Slide the button assembly out from the top cover through the opening.
2 участников успешно повторили данное руководство.
