Logitech MBJ58 Mouse Resistance Spring Replacement
Выберете то, что вам нужно
  1. Logitech MBJ58 Mouse Resistance Spring Replacement, Top cover: шаг 1, изображение 1 из 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
    باز کردن پیچ زیر موس
    h sh - Ответить
    There may be a sticker covering the screw hole.
    Eric Jensen - Ответить
  2. Logitech MBJ58 Mouse Resistance Spring Replacement: шаг 2, изображение 1 из 2 Logitech MBJ58 Mouse Resistance Spring Replacement: шаг 2, изображение 2 из 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
    جدا کردن قاب رو و زیر موس
    h sh - Ответить
    The cover doesn’t lift straight up on my model - once you raise the back slightly as shown, gently pull it backward (parallel to the table top, away from the cord) to disengage two plastic clips that connect the bottom to the top.
  3. Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: шаг 3, изображение 1 из 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: шаг 3, изображение 2 из 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: шаг 3, изображение 3 из 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
    خارج کردن چرخ اسکرول موس
    h sh - Ответить
    Good information!
    My mouse is like new again.
    Many thanks
    Arie Dekker - Ответить
  4. Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: шаг 4, изображение 1 из 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: шаг 4, изображение 2 из 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
    نحوه قرارگیری فنر سمت راست چرخ اسکرول
    h sh - Ответить
  5. Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: шаг 5, изображение 1 из 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: шаг 5, изображение 2 из 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    h sh - Ответить
  6. Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: шаг 6, изображение 1 из 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: шаг 6, изображение 2 из 3 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: шаг 6, изображение 3 из 3
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
    نحوه قرارگیری فلز سمت چپ چرخ اسکرول
    h sh - Ответить
  7. Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: шаг 7, изображение 1 из 2 Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: шаг 7, изображение 2 из 2
    • Grasp the top of the resistance spring and pull it towards yourself, letting the hook slide out of its hole.
  8. Logitech MBJ58 Mouse Resistance Spring Replacement: шаг 8, изображение 1 из 1
    • Insert the hooked section of the replacement spring into the corresponding hole on the mount.
    Thank you, thank you, THANK YOU! Worked for Click! Cordless Optical too. I had taken the mouse cover off for cleaning. It was a mess inside. Lifting the wheel out, those two springs fell off. I had no clear idea how to re-assemble them... until you. How much do I owe you? I'd gladly pay.
    Lawrence
    Lawrence W. McAllister - Ответить
Заключение
14 участников успешно повторили данное руководство.
Maximilian Betkowski
Участник с: 01/11/13
235 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 5-14, Forte Winter 2013 Участник Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 членов
Автор 21 руководств
10 Комментариев
This mouse was also available from Dell as an OEM device under the model name "M-UVDEL1". Hopefully the Google juice will help folks repair their devices. I know I would have spent far more time than I did if it weren't for the photos on how to put the spring back. Thanks Maximilian!
Bastien Nocera - Ответить
The spring installation details were lifesavers. Thank you!
LB
byard - Ответить
thank you! could not have done it without your help.
taiyo_yuden_dvd - Ответить
Brilliant. Thanks. Easy once you know how. The springs were the hard part.
Charles Thomson - Ответить
Thank you so much!! You made it very easy and quick!
vulcanmeister - Ответить
Used this to figure out how to return the support spring to the correct position for a model M-BJ67B.
THANKS!!
fracjackmac - Ответить
Do you have a part number for the resistance spring? I dropped mine and can’t find a new one on the Internet anywhere.
Aidan Franits - Ответить
The spring fell out when I took mine apart (without reading these instructions) your guide was amazingly useful and clear for me to successfully put it back together. Thank you
Jom Bom - Ответить
Also works for Lenovo M-UAE119
Andy Higgs - Ответить
Where can you buy a replacement spring for the click part? My boyfriend dropped it on the ground while trying to examine it and it's so tiny it disappeared, he really likes this mouse so he doesn't want to just buy a new one. Does anyone sell the individual tiny springs under the click part of the mouse?
lil_e - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 16
За последние 30 дней: 75
За всё время: 10,929
