Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
You will learn how to remove and install the support spring.
Выберете то, что вам нужно
Hold the mouse so that the bottom is facing up.
Remove the single Phillips #1 screw from the bottom half of the mouse.
Place the mouse so that the bottom is resting against a hard surface.
Lift the top cover of the mouse gently, and remove it.
Locate the scroll wheel on the mouse.
Grab the scroll wheel with your thumb and index finger.
Gently lift up, to remove the scroll wheel from the mouse.
Locate the spring on the scroll wheel. The spring is a small piece of metal wire coiled in the middle.
Carefully remove the spring from the wheel scroll.
Replace the spring, place it on the correct side of the wheel with the prongs pointing down.
6 участников успешно повторили данное руководство.
