Logitech MX Master 3 Mouse Feet Replacement
Выберете то, что вам нужно
  1. Logitech MX Master 3 Mouse Feet Replacement, Soften the mouse feet adhesive: шаг 1, изображение 1 из 3 Logitech MX Master 3 Mouse Feet Replacement, Soften the mouse feet adhesive: шаг 1, изображение 2 из 3 Logitech MX Master 3 Mouse Feet Replacement, Soften the mouse feet adhesive: шаг 1, изображение 3 из 3
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to each of the mouse feet for about one minute each.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
    • The information sticker adhesive may soften during this step, but you don't need to remove it.
  2. Logitech MX Master 3 Mouse Feet Replacement, Separate the mouse foot adhesive: шаг 2, изображение 1 из 3 Logitech MX Master 3 Mouse Feet Replacement, Separate the mouse foot adhesive: шаг 2, изображение 2 из 3 Logitech MX Master 3 Mouse Feet Replacement, Separate the mouse foot adhesive: шаг 2, изображение 3 из 3
    • Slide an opening pick under an edge of the left mouse foot.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • If the foot feels stuck, apply more heat before continuing.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Peel up and remove the left mouse foot.
  3. Logitech MX Master 3 Mouse Feet Replacement, Remove the right and rear mouse feet: шаг 3, изображение 1 из 2 Logitech MX Master 3 Mouse Feet Replacement, Remove the right and rear mouse feet: шаг 3, изображение 2 из 2
    • Repeat the previous two steps to remove the right and the rear mouse feet.
  4. Logitech MX Master 3 Mouse Feet Replacement, Reassembly information: шаг 4, изображение 1 из 3 Logitech MX Master 3 Mouse Feet Replacement, Reassembly information: шаг 4, изображение 2 из 3 Logitech MX Master 3 Mouse Feet Replacement, Reassembly information: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Купить
    • If the adhesive separated from the foot:
    • Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive.
    • For installing new mouse feet or reusing your old ones:
    • Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  5. Logitech MX Master 3 Mouse Feet Replacement, Remove the front mouse foot: шаг 5, изображение 1 из 1
    • Remove the front mouse foot.
Заключение
Еще один человек закончил это руководство.
Adam O'Camb
Участник с: 04/11/15
197 238 Репутация
Автор 416 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 16
За последние 7 дней: 77
За последние 30 дней: 294
За всё время: 8,074
