Logitech Pure-Fi Anywhere 2 Battery Replacement
Выберете то, что вам нужно
  1. Logitech Pure-Fi Anywhere 2 Battery Replacement, Loosening cosmetic plastic cover: шаг 1, изображение 1 из 2 Logitech Pure-Fi Anywhere 2 Battery Replacement, Loosening cosmetic plastic cover: шаг 1, изображение 2 из 2
    • To avoid damage to the outside of the casing create a first opening with a plastic opening tool.
    • Insert the metal spudger in the opening you just created.
  2. Logitech Pure-Fi Anywhere 2 Battery Replacement: шаг 2, изображение 1 из 2 Logitech Pure-Fi Anywhere 2 Battery Replacement: шаг 2, изображение 2 из 2
    • Now work your way along all sides, cuting through the glue with the spudger. The glue is all over so make make sure to go deep enough under the cover with the spudger.
  3. Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: шаг 3, изображение 1 из 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: шаг 3, изображение 2 из 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Removing cosmetic cover: шаг 3, изображение 3 из 3
    • Remove the plastic cover to get access to the screws.
    • The glue will still stick when reassambling the Pure-Fi Anywhere.
  4. Logitech Pure-Fi Anywhere 2 Battery Replacement, Unscrew front cover: шаг 4, изображение 1 из 1
    • Remove the eight Phillips screws securing the front cover to the back cover.
  5. Logitech Pure-Fi Anywhere 2 Battery Replacement, Open the device: шаг 5, изображение 1 из 2 Logitech Pure-Fi Anywhere 2 Battery Replacement, Open the device: шаг 5, изображение 2 из 2
    • Lift the front cover up away from the back cover. Do not pull them apart too far though as the battery is secured to the back cover while everything else is secured to the front cover.
    • Chances are that the wires running from the battery itself to the connector are firmly tucked behind the battery making it hard to get a grip on the connecter so just leave it connected for now.
  6. Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: шаг 6, изображение 1 из 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: шаг 6, изображение 2 из 3 Logitech Pure-Fi Anywhere 2 Battery Replacement, Remove battery cover: шаг 6, изображение 3 из 3
    • Remove the two Phillips screws securing the battery cover.
    • Remove the battery cover to finaly get access to the battery.
    • Now you can get a good grip on the battery connector to disconnect it.
    • Replace with new battery!
  7. Logitech Pure-Fi Anywhere 2 Battery Replacement: шаг 7, изображение 1 из 1
    • Chances are your replacement battery doesn't have foam tape taped around it. If you don't have a roll of foam tape lying around at home just gently peel off the tape from the old battery and aply it to the new battery. This will ensure that the battery will firmly be secured under the battery cover.
Заключение
17 участников успешно повторили данное руководство.
EricV
Участник с: 08/01/15
758 Репутация
Автор 2 руководств
6 Комментариев
Excellent guide. Thanks for taking the trouble to include numerous pictures - it makes all the difference. I found separating the glue from the cover was a bit daunting but once apart the rest was easy.
Andrew - Ответить
FANTASTIC!!
this really helped me resurect one of my favourite Products which would have otherwise ended up in the trash!
chris - Ответить
Amazing bro, i was suspecting that could be the way of doing it, but was too afraid of breaking it.
rodri_opomoz - Ответить
Worked for me! Good guide. BTW: the speaker has amazing sound
David Lai - Ответить
Good guide. I did not want to spend $14.00 for a battery. I took apart an old hp laptop battery which has 6 cells in it. Checked and they were not completely dead. Removed 2 cells ( I have 2 of these iPod docks). Soldered the small control board/ harness to the “new” cells. Works. Getting a little over 4hrs played at second loudest volume. Good enough. Have 2 working units for zero cost. Just ordered a Bluetooth iPod adapter ($4.60) so I can be full wireless. Really good sound too.
Steve Solorio - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 13
За последние 30 дней: 74
За всё время: 9,912
