Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement
Выберете то, что вам нужно
  1. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: шаг 1, изображение 1 из 3 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: шаг 1, изображение 2 из 3 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement, Dock Adapter Cover: шаг 1, изображение 3 из 3
    • To remove the plastic cover, use the plastic opening tool at the corner of the device.
    • Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
    • Caution: Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
    • Caution: Carefully remove the cover as it is easy to break.
  2. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: шаг 2, изображение 1 из 2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: шаг 2, изображение 2 из 2
    • Remove the eight 10.5 mm Phillips #1 screws securing the cover.
    • Remove three 5.2 mm Philips #1 screws securing the dock.
  3. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: шаг 3, изображение 1 из 2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: шаг 3, изображение 2 из 2
    • Use the metal spudger to loosen the front cover to get into the inner part of the device.
    • Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use the metal spudger carefully to avoid any unnecessary damages.
    • Make sure to carefully lift up the front cover from the back cover.
    • There are wires connecting to between battery and the cover.
  4. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: шаг 4, изображение 1 из 2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: шаг 4, изображение 2 из 2
    • Identify the small circuit board attached to the dock adapter cover.
    • remove two 2.5 mm Phillips #1 screws at the circuit board.
  5. Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: шаг 5, изображение 1 из 2 Logitech Pure-Fi Anywhere 2 Dock Adapter Cover Replacement: шаг 5, изображение 2 из 2
    • Carefully take out the dock adapter cover from the device.
    • It might needs few try to pull out the small circuit board.
    • Take out the broken dock adapter cover and replace with the new one.
Заключение
ali alhashim
Участник с: 07/18/18
121 Репутация
1 руководство автора
Команда
IUPUI, Team S4-G4, Wilson Summer 2018 Участник IUPUI, Team S4-G4, Wilson Summer 2018
IUPUI-WILSON-SU18S4G4
4 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 5
За последние 30 дней: 18
За всё время: 827
