Выберете то, что вам нужно
To remove the plastic cover, use the plastic opening tool at the corner of the device.
Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
Remove the eight 10.5 mm Phillips #1 screws securing the cover.
Remove three 5.2 mm Philips #1 screws securing the dock.
Use the metal spudger to loosen the front cover to get into the inner part of the device.
Make sure to carefully lift up the front cover from the back cover.
Identify the small circuit board attached to the dock adapter cover.
remove two 2.5 mm Phillips #1 screws at the circuit board.
Carefully take out the dock adapter cover from the device.
Take out the broken dock adapter cover and replace with the new one.
