Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement
Выберете то, что вам нужно
  1. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: шаг 1, изображение 1 из 3 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: шаг 1, изображение 2 из 3 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement, Inner Speaker Cones: шаг 1, изображение 3 из 3
    • To remove the plastic cover. You want to use the plastic opener and starting with corners.
    • Then insert the metal spudger in the opening and slowly move the metal spudger along all sides of the cover.
    • Caution: Metal spudger can damage the internal components of the device such as the motherboard. Make sure to use it carefully in order to avoid any unnecessary damages.
    • Make sure the metal supdger is inserted deep enough as the cover is glued to the device.
    • Carefully remove the cover as it can be very fragile
  2. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: шаг 2, изображение 1 из 3 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: шаг 2, изображение 2 из 3 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: шаг 2, изображение 3 из 3
    • Remove eight 10.5 mm Phillips #1 screws from the cover.
    • Insert a metal spurger at the corner to help loosen the cover.
    • There is still glue sticking the front cover and the back cover together.
    • Starting with corners, lift up the cover slowly and carefully.
    • Do not pull too hard when removing the cover. There are wires connecting between the battery and the circuit board.
  3. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: шаг 3, изображение 1 из 2 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: шаг 3, изображение 2 из 2
    • Identity the speaker cover, and remove four 4.5 mm Phillips #1 screws.
    • Lift up the cone. It should be removed very easily by hand.
  4. Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: шаг 4, изображение 1 из 2 Logitech Pure-Fi Anywhere 2 Inner Speaker Cones Replacement: шаг 4, изображение 2 из 2
    • Remove four 5.2mm Phillips #1 screws that are securing the circuit board.
    • Unplug the connecting wire from the circuit board. Carefully lift up the circuit board.
    • Same as step 3, remove four 4.5 mm Phillips #1 screws from the speaker cone.
Заключение
junyi yang
Участник с: 07/11/18
109 Репутация
1 руководство автора
Команда
IUPUI, Team S4-G4, Wilson Summer 2018 Участник IUPUI, Team S4-G4, Wilson Summer 2018
IUPUI-WILSON-SU18S4G4
4 членов
Автор 2 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 6
За последние 30 дней: 22
За всё время: 1,221
