Logitech UE MegaBoom 3 Passive Radiator Replacement
Выберете то, что вам нужно
  1. Logitech UE MegaBoom 3 Passive Radiator Replacement, General Disassembly: шаг 1, изображение 1 из 2 Logitech UE MegaBoom 3 Passive Radiator Replacement, General Disassembly: шаг 1, изображение 2 из 2
    • To access all internal components, first flip the speaker upwards to where you can see the base.
    • Place your blue iFixit opening picks inside the gap between the speaker and the base to act as a lever when opening the speaker.
  2. Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 2, изображение 1 из 3 Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 2, изображение 2 из 3 Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 2, изображение 3 из 3
    • Using the flat head #4.5 screw driver, carefully lever and rotate the driver around the edge of the speaker to enlarge the gap further.
    • Here, it is ideal to use a spudger as opposed to the flathead screwdriver, however, the flathead makes it so much easier to pry off the cap.
    • Pry off the base of the speaker and remove the end cap.
  3. Logitech UE MegaBoom 3 Passive Radiator Replacement, Power Button Control Board: шаг 3, изображение 1 из 3 Logitech UE MegaBoom 3 Passive Radiator Replacement, Power Button Control Board: шаг 3, изображение 2 из 3 Logitech UE MegaBoom 3 Passive Radiator Replacement, Power Button Control Board: шаг 3, изображение 3 из 3
    • Take off the fiber cover by prying it from the top of the speaker using the flathead 4.5 mm screwdriver.
    • After the cover is loosened, the cap can finally be pulled off.
  4. Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 4, изображение 1 из 3 Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 4, изображение 2 из 3 Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 4, изображение 3 из 3
    • Remove the top half of the speaker using the 4.5 mm flat head screwdriver.
    • Now remove the top of the speaker by prying and releasing the tab around the cap using the same screwdriver.
  5. Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 5, изображение 1 из 3 Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 5, изображение 2 из 3 Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 5, изображение 3 из 3
    • With the cap removed, using Phillips #0 screwdriver remove all four 2.0 mm screws to take off the control board.
    • Now you can replace the power button control board.
  6. Logitech UE MegaBoom 3 Passive Radiator Replacement, Passive Radiator: шаг 6, изображение 1 из 2 Logitech UE MegaBoom 3 Passive Radiator Replacement, Passive Radiator: шаг 6, изображение 2 из 2
    • Take off the metal rods by gently prying them out using the metal spudgers
    • Be sure to slide them out as gently as possible to prevent the rods from becoming damaged.
  7. Logitech UE MegaBoom 3 Passive Radiator Replacement: шаг 7, изображение 1 из 1
    • One the rods are removed you can pry it off and disconnect the passive radiator.
    • Repeat the same steps to disconnect the passive radiator on the other side of the speaker.
Заключение
2 участников успешно повторили данное руководство.
Anthony Miles
Участник с: 09/04/23
981 Репутация
Автор 6 руководств
Команда
University of Memphis, Team 1-2, Sneed Fall 2023 Участник University of Memphis, Team 1-2, Sneed Fall 2023
UM-SNEED-F23S1G2
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 20
За всё время: 143
