Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement
Выберете то, что вам нужно
  1. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: шаг 1, изображение 1 из 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: шаг 1, изображение 2 из 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Outer Mesh: шаг 1, изображение 3 из 3
    • Locate the ends of the speaker.
    • Put a plastic opening tool in-between the rubber end and the mesh.
    • Apply a upward force in order to pry open the end.
    • Apply this procedure to the other side as well.
    • Will take force.
    • Using metal tools may permanently mar your device.
  2. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 2, изображение 1 из 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 2, изображение 2 из 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 2, изображение 3 из 3
    • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
    • You will hear clicks as it pries up, don't worry.
    • Remove all the rubber you pried off.
  3. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 3, изображение 1 из 2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 3, изображение 2 из 2
    • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
    • Work the plastic retainer out of the channel all the way around the speaker.
    • Be gentle, it is easy to damage the fabric.
    • Repeat for other side.
  4. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: шаг 4, изображение 1 из 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: шаг 4, изображение 2 из 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement, Auxiliary Port and micro USB Port: шаг 4, изображение 3 из 3
    • Apply an upward force with your thumbs to loosen the end cap.
    • Grasp the end cap and lift up to seperate it from the base.
  5. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 5, изображение 1 из 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 5, изображение 2 из 3 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 5, изображение 3 из 3
    • Use tweezers or an opening tool to remove the plastic insert on the inside of the rubber seal.
    • Push up on the rectangular connector from the bottom to loosen the circuit board.
  6. Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 6, изображение 1 из 2 Logitech UE MegaBoom Auxiliary Port and micro USB Port Assembly Replacement: шаг 6, изображение 2 из 2
    • Now grasp the plastic on the outside of the rubber seal and pull it out by applying an upward force.
    • Once the plastic has been removed, pull out the circuit board containing the auxiliary and USB ports.
Заключение
3 участников успешно повторили данное руководство.
Oscar Ambriz
Участник с: 09/27/17
958 Репутация
Автор 6 руководств
Команда
Cal Poly, Team S9-G2, Banghart Fall 2017 Участник Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 членов
Автор 14 руководств
10 Комментариев
How can I purchase this part being replaced thanks
Joseph Anderson - Ответить
where can i get that part the whole board usb aux i need to replace due to water damage
jdw vlogs - Ответить
I also need this part due to water damage. Where Do I order this entire motherboard at?
dersert6bunnie - Ответить
Hello. Did you find the spare part?
Ionut -
I don’t think you can buy the parts new. Try buying a used/broken speaker for parts that has a working part that you need.
Nick Johnston - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 21
За последние 30 дней: 94
За всё время: 11,321
