Введение
A dead battery can be an inexpensive fix for devices that will not charge, or have a short battery life. This guide will show you how this part can be replaced.
Выберете то, что вам нужно
Locate the ends of the speaker.
Put a plastic opening tool in-between the rubber end and the mesh.
Apply a upward force in order to pry open the end.
Apply this procedure to the other side as well.
Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
Remove all the rubber you pried off.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
Work the plastic retainer out of the channel all the way around the speaker.
Repeat for other side.
Remove inner plastic gasket on circuit board.
Remove 2nd plastic gasket around outer circuit board edge, under rubber gasket.
17 человек успешно провели ремонт по этому руководству.
24 Комментарии к руководству
There is a way to take it apart without all these steps and a complete tear down.
This is huge overkill. Only the bottom cap and circuit board need to be removed for a battery replacement.
I agree. The battery is located on the bottom end only.
Jamin Hu -
^ the person who says that you only need to remove the one end-cap to replace the battery is correct. The process outlined in this article is more likely to damage all the fabric and other end-cap than just opening one end and gently prying it back until you can slide out the battery. FYI, the pull tab on my battery broke right off, and I had to pull it out with pliers.
