Logitech Z4 Desk Speaker Disassembly
Выберете то, что вам нужно
  1. Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: шаг 1, изображение 1 из 3 Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: шаг 1, изображение 2 из 3 Logitech Z4 Desk Speaker Disassembly, Unscrewing the speaker stand: шаг 1, изображение 3 из 3
    • Use a PH2 screwdriver to remove the two screws on the back of the speaker.
    • the speaker has a cinch connector to plug in to the sub-woofer.
  2. Logitech Z4 Desk Speaker Disassembly, Removing frontpanel: шаг 2, изображение 1 из 2 Logitech Z4 Desk Speaker Disassembly, Removing frontpanel: шаг 2, изображение 2 из 2
    • removing the decorative front panel with a plastic pick (guitar picks work great). it is quite sturdy but the adhesive film on the back of it is strong, so go slow or heat it up with a hairdryer.
  3. Logitech Z4 Desk Speaker Disassembly, Removing the housing screws: шаг 3, изображение 1 из 1
    • removing the main screws for the speaker housing. using the same driver (PH2) we can remove the 8 screws holding the main speaker assembly together.
  4. Logitech Z4 Desk Speaker Disassembly, Opening the speaker housing: шаг 4, изображение 1 из 2 Logitech Z4 Desk Speaker Disassembly, Opening the speaker housing: шаг 4, изображение 2 из 2
    • opening the speaker housing by prying it up evenly on all sides with the plastic pick.
    • it can be tapped lightly on the desk to make it fall out at the end of the process.
  5. Logitech Z4 Desk Speaker Disassembly, Taking inventory: шаг 5, изображение 1 из 3 Logitech Z4 Desk Speaker Disassembly, Taking inventory: шаг 5, изображение 2 из 3 Logitech Z4 Desk Speaker Disassembly, Taking inventory: шаг 5, изображение 3 из 3
    • after opening the speaker fully you can see that the top and bottom membranes are not speakers, only decoration.
    • the middle one is connected with two wires matching the cinch connector on the cable.
    • the cable has a screw and some hot glue acting as a strain release for the cable.
Заключение
6 человек успешно провели ремонт по этому руководству.
kugelzucker
Участник с: 03/08/16
342 Репутация
1 руководство автора
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 15
За последние 30 дней: 68
За всё время: 3,499
