Введение
In this guide, an Enkeeo Longboard was used. This guide should be used to replace the bearings on similar longboards with new bearings. You can also clean existing bearings or replace other parts, like wheels, washers, or spacers.
The bearings of the longboards keep the wheels rotating freely, with minimal friction. It is important to replace worn out longboard bearings because if they fail it can lead to an unexpected crash. If you have faulty bearings, like after an incident, this is the perfect guide to use. Also, have spare parts and be sure you are using the same sized bearings. Some boards can have a different size bearing.
The video below shows step-by-step how to replace bearings: https://www.youtube.com/watch?v=W6FUcvZj...
Выберете то, что вам нужно
On a flat surface, unscrew the nut that holds the wheel on the axle using the correct size from the skateboard tool (1/2" size, typically the smaller of the 2 on the top of the 'T') and turning to the left.
Use the pointy end of the small tool that comes with the Skate Tool and insert it under the bearing (look at the red arrow) to pry (and we mean PRY) out one of the bearings.
We recommend starting with the bearing on side of the wheel that stays closest to the board and prying in the direction of the green arrow.
Remove the spacer that sits between the bearings on the inside of the wheel.
Pry out the other bearing.
Insert one of the new bearings into the wheel. It should not matter what way you put it in unless they are specialty bearings.
Push until it stops against the built in stopper within the wheel.
Place in the spacer that goes between the bearings on the inside.
Repeat step 5 to insert the other bearing on the other side of the wheel.
Put the outside spacer back on the axle of the board.
Put the wheel back on in the proper orientation.
Using the 1/2" side of the Skate Tool, screw the nut back on the axle to hold the wheel in place.
To replace the bearings on the other wheels, repeat steps.
2 участников успешно повторили данное руководство.
