Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
On a flat surface, unscrew the nut that holds the wheel on the axle using the correct size from the skateboard tool (1/2" size, typically the smaller of the 2 on the top of the 'T') and turning to the left.
Use the pointy end of the small tool that comes with the Skate Tool and insert it under the bearing (look at the red arrow) to pry (and we mean PRY) out one of the bearings.
We recommend starting with the bearing on side of the wheel that stays closest to the board and prying in the direction of the green arrow.
Remove the spacer that sits between the bearings on the inside of the wheel.
Pry out the other bearing.
Insert one of the new bearings into the wheel. It should not matter what way you put it in unless they are specialty bearings.
Push until it stops against the built in stopper within the wheel.
Place in the spacer that goes between the bearings on the inside.
Repeat step 5 to insert the other bearing on the other side of the wheel.
Put the outside spacer back on the axle of the board.
Put the wheel back on in the proper orientation.
Using the 1/2" side of the Skate Tool, screw the nut back on the axle to hold the wheel in place.
Test the wheel by spinning it on the board to check that it moves freely.
2 участников успешно повторили данное руководство.
