Введение
Is your receiver's sound distorted, or not producing sound when watching video? Try replacing the speaker to solve this problem.
Выберете то, что вам нужно
Remove the battery cover on the back of the LCD monitor by unscrewing one 5mm Phillips #1 screw.
Slide the battery out of the housing. Lightly tap the opposite end of the monitor if the battery does not come right out.
Using a plastic opening tool, gently separate the back panel from the front panel, working the tool around the panel to disconnect it.
Carefully remove the back panel
Locate the motherboard and carefully pull the red and black speaker wires out of their harness.
Using a metal spudger, pry the melted black plastic away from the speaker.
Carefully pull the speaker out of its housing by the wires.
Еще один человек закончил это руководство.
