Введение
- Device name: MECHREVO Z2
- The purpose of this guide is to replace the RAM of your laptop.
- If your MECHREVO Z2 Laptop gets slow in use, you may need to replace or add RAM to your Laptop.
- Please disconnect the power supply before working.
- RAM
Выберете то, что вам нужно
Using a Phillips screwdriver, remove eighteen 1.2mm Phillips #1 screws on the back.
Open the retaining latches on either side of the RAM card with your fingers or plastic tool.
Remove the RAM.
Align the notched part of the RAM with the raised part of the card slot.
Push inward until the notch and bulge coincide.
Press the other end of RAM down with your finger.
要放大说明您的设备,请进行这些操作。
要放大说明您的设备,请进行这些操作。
5 участников успешно повторили данное руководство.
2 Комментариев
here is the link:
