MFC-J4410DW Ink Absorber Box Replacement
Выберете то, что вам нужно
  1. MFC-J4410DW Ink Absorber Box Replacement, Preparation: шаг 1, изображение 1 из 3 MFC-J4410DW Ink Absorber Box Replacement, Preparation: шаг 1, изображение 2 из 3 MFC-J4410DW Ink Absorber Box Replacement, Preparation: шаг 1, изображение 3 из 3
    • Before beginning disassembly, turn off the printer and unplug the power cord.
    • Open the front access door and remove any cards or cables present. Close the access door.
    • Remove the paper tray.
    • Remove the ink cartridges.
    • You may wish to install the Protective Part to prevent the ink tubes from drying while the cartridges are removed.
    • Open the printer cover using the finger holds on the sides.
    • Unplug and remove any cords present under the cover.
    • Remove the LAN port and EXT port caps (if present).
  2. MFC-J4410DW Ink Absorber Box Replacement, Removing the cover support: шаг 2, изображение 1 из 3 MFC-J4410DW Ink Absorber Box Replacement, Removing the cover support: шаг 2, изображение 2 из 3 MFC-J4410DW Ink Absorber Box Replacement, Removing the cover support: шаг 2, изображение 3 из 3
    • While holding the cover with one hand, pull the hook on the back of the support damper, then remove the damper from the cover.
    • Remove the damper from the support.
    • Turn the support upright and pull it straight out of the printer.
  3. MFC-J4410DW Ink Absorber Box Replacement, Removing the harness cover: шаг 3, изображение 1 из 2 MFC-J4410DW Ink Absorber Box Replacement, Removing the harness cover: шаг 3, изображение 2 из 2
    • Use your finger or a spudger to unhook the two tabs on the right side of the harness cover by levering it up.
    • Remove the harness cover. There are two tabs on the left side that you have to wiggle free, and one on the front.
  4. MFC-J4410DW Ink Absorber Box Replacement, Removing the grounding screw: шаг 4, изображение 1 из 1
    • Remove the 6 mm Phillips #2 screw from the grounding wire of the ADF motor harness.
    • Torque: 0.40±0.10 N•m
    • The Brother service manual lists torques for all screws, but proper torque should not be necessary.
  5. MFC-J4410DW Ink Absorber Box Replacement: шаг 5, изображение 1 из 1
    • In the proceeding steps, you will disconnect the following cables:
    • CIS flat cable
    • Scanner motor harness
    • ADF motor harness
    • Document detection/document scanning position sensor harness
  6. MFC-J4410DW Ink Absorber Box Replacement: шаг 6, изображение 1 из 1
    • Pull the CIS flat cable out of its socket.
    • Pull all flat cables directly up out of their sockets, pulling on the cables themselves at the blue tabs.
  7. MFC-J4410DW Ink Absorber Box Replacement: шаг 7, изображение 1 из 1
    • Pull the scanner motor harness out of its socket.
  8. MFC-J4410DW Ink Absorber Box Replacement: шаг 8, изображение 1 из 1
    • Pull the ADF motor harness out of its socket.
  9. MFC-J4410DW Ink Absorber Box Replacement: шаг 9, изображение 1 из 1
    • Pull the document detection/document scanning position sensor harness out of its sockets.
  10. MFC-J4410DW Ink Absorber Box Replacement, Opening the scanner harness holder: шаг 10, изображение 1 из 2 MFC-J4410DW Ink Absorber Box Replacement, Opening the scanner harness holder: шаг 10, изображение 2 из 2
    • Insert a spudger between the scanner harness holder and frame to release the tab. There is a second tab on the opposite side.
    • Lift the scanner harness holder out of its frame.
    • Reassembly Note: Before reattaching the harness holder, it is advisable to reattach the cover support (Step 2) to minimize tension on the wiring harnesses.
  11. MFC-J4410DW Ink Absorber Box Replacement, Securing the scanner harness holder: шаг 11, изображение 1 из 2 MFC-J4410DW Ink Absorber Box Replacement, Securing the scanner harness holder: шаг 11, изображение 2 из 2
    • Push on the tab to secure the scanner harness holder to the scanner cover.
    • De-route the document detection/document scanning position sensor harness and the ADF motor harness from the scanner harness holder.
    • During reassembly, put a 20mm-thick pad (book, stack of paper) on the scanner glass, close the scanner cover, then route the document detection/document scanning position sensor harness and the ADF motor harness through the harness holder. This will ensure the proper harness tension to allow scanning of thick books.
  12. MFC-J4410DW Ink Absorber Box Replacement, Removing the scanner cover: шаг 12, изображение 1 из 1
    • Using both hands, pull the scanner cover to the rear while holding it vertically, then lift it off of the printer.
  13. MFC-J4410DW Ink Absorber Box Replacement, Removing the upper cover: шаг 13, изображение 1 из 2 MFC-J4410DW Ink Absorber Box Replacement, Removing the upper cover: шаг 13, изображение 2 из 2
    • Remove the six 12 mm Phillips #2 screws securing the upper cover to the printer.
    • Torque: 0.70±0.10 N•m
    • Pull off the upper cover.
    • When reinstalling, ensure that the control panel wiring holder slides into its slot on the upper cover.
  14. MFC-J4410DW Ink Absorber Box Replacement, Removing the ink absorber box wiring: шаг 14, изображение 1 из 2 MFC-J4410DW Ink Absorber Box Replacement, Removing the ink absorber box wiring: шаг 14, изображение 2 из 2
    • Remove the ink absorber full sensor from its socket.
    • De-route the wiring from its harness.
  15. MFC-J4410DW Ink Absorber Box Replacement, Unhooking the ink absorber: шаг 15, изображение 1 из 1
    • Unclip the ink absorber from the harness by pulling it up and to the right.
  16. MFC-J4410DW Ink Absorber Box Replacement, Removing the tubes: шаг 16, изображение 1 из 3 MFC-J4410DW Ink Absorber Box Replacement, Removing the tubes: шаг 16, изображение 2 из 3 MFC-J4410DW Ink Absorber Box Replacement, Removing the tubes: шаг 16, изображение 3 из 3
    • For this step, spin the printer around so the back is toward you.
    • Remove the drain tube and the air vent tube from the ink absorber box. A spudger may be helpful.
    • Clip the ends of the tubes so they won't leak.
    • De-route the tubes from the holder.
  17. MFC-J4410DW Ink Absorber Box Replacement, Removing the ink absorber box: шаг 17, изображение 1 из 1
    • Rotate the ink absorber box 90º vertically, and pull it up out of its socket.
Заключение
To reassemble your device, follow these instructions in reverse order. You may also wish to replace the flushing box at this time.
Screw torques from the service manual have been included if you happen to have a torque screwdriver, but don’t worry about them if you don’t.
After reassembly, follow the following steps to reset the purge count in order to clear the “Ink Absorber Full” error:
  1. Plug the printer in and turn it on.
  2. Press the Home button (the house icon) on the front of the printer until the Maintenance Mode screen appears (approximately five seconds).
  3. Hold down the blank button at the bottom of the screen until a number keypad appears on the screen (approximately two seconds).
  4. Press *******, 286 and 4 (you can use the onscreen keypad or the printer’s built-in keypad for this). The printer will beep and MAINTENANCE will appear on the screen.
  5. Press 8 and 0.
  6. Press the down arrow repeatedly until PURGE: (or FLUSHING:) appears on the screen.
  7. Press 278 and 3. The printer will beep and MAINTENANCE will again appear on the screen.
  8. Press 9 twice to exit maintenance mode and reboot the printer. You can also use this to start over if you make an error.
If this guide was helpful, why not buy the author a coffee?
66 человек успешно провели ремонт по этому руководству.
Calion
Участник с: 12/24/10
4 144 Репутация
Автор 3 руководств
Команда
Syler Solutions Участник Syler Solutions
Business
1 член
Автор 13 руководств
57 Комментарии к руководству
Useful for dismantling the printer although my problem wasn’t with the waste ink component
Rob Hindle - Ответить Поделиться
Well, feel free to make a guide based on this one for whatever your problem was!
Calion - Поделиться
Calion, you are my hero! The one place I’ve found where I can buy the replacement waste box for my Brother MFC-J4510DW does not provide directions on how to install it. And Brother itself offers neither the part nor the instructions. I thought I was going to have to buy a new printer until I came across your excellent report! Thanks so much for doing this!
haroldsogard - Ответить Поделиться
You’re welcome! Very glad I could help out!
Calion - Поделиться
Very informative and helpful :-)
Question could you fit a external waste ink tank ? what size are the waste ink tubes?
George Duthie - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 24
За последние 7 дней: 227
За последние 30 дней: 968
За всё время: 79,506
