Введение
Use this guide to replace an aging or faulty battery cell. MNT Reform uses eight 18650 3.2V LiFePO4 batteries in series, which can be replaced individually.
When fully charged, the battery cells combine to a voltage of almost 29 volts, and can easily deliver multiple amperes of current. Do not touch the metal pins of the battery holders with metal tools.
Выберете то, что вам нужно
Remove the following screws securing the transparent acrylic bottom plate to the main box:
Ten M2×6mm silver Phillips screws
Pull out the eight battery cells one by one, and set them aside safely.
To reassemble your device, follow these instructions in reverse order. Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
Еще один человек закончил это руководство.
