Введение
This guide will show the replacement of the webcam on the MSI Apache Pro 004 laptop.
Выберете то, что вам нужно
Remove the 15 screws from the bottom of the laptop with a PH1 screwdriver.
Remove the bottom plate
Remove the screw holding down the battery with a PH1 screwdriver.
Pull out the battery.
Slide a metal opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
Locate the WebCam on the middle of the device.
Slide a metal opener tool to remove the Webcam
