Введение
This guide will teach you how to replace the SSD on your MSI GE72 6QF Apache Pro
Инструменты
Запчасти
Детали не указаны.
With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
Using your fingers, gently loosen the edges of all four sides of the back cover.
Gently pull off the back cover.
Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
7 участников успешно повторили данное руководство.
