Введение
Though the screen for this laptop can be costly, replacing the screen is quite simple. Be cautious when removing the screen bezel so that it will reattach correctly.
Запчасти
  1. MSI GE72 6QF Apache Pro Screen Replacement, Screen: step 1, image 1 of 3 MSI GE72 6QF Apache Pro Screen Replacement, Screen: step 1, image 2 of 3 MSI GE72 6QF Apache Pro Screen Replacement, Screen: step 1, image 3 of 3
    • Be careful when removing the bezel. The clips that hold it in place will break when too much pressure is applied.
    • Use the plastic opening tool to carefully pop the screen bezel off of the laptop.
  2. MSI GE72 6QF Apache Pro Screen Replacement: step 2, image 1 of 3 MSI GE72 6QF Apache Pro Screen Replacement: step 2, image 2 of 3 MSI GE72 6QF Apache Pro Screen Replacement: step 2, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the four 3mm long screws.
  3. MSI GE72 6QF Apache Pro Screen Replacement: step 3, image 1 of 3 MSI GE72 6QF Apache Pro Screen Replacement: step 3, image 2 of 3 MSI GE72 6QF Apache Pro Screen Replacement: step 3, image 3 of 3
    • Flip the screen over and carefully peel off the tape that holds the connector in place.
    • When peeling off the tape, fold it back so that it can remain sticky for the new screen.
Заключение
2 участников успешно повторили данное руководство.
Riley Smith
Участник с: 22.09.2017
779 Репутация
Автор 4 руководств
Команда
Central Washington University, Team S1-G2, Pengilly Fall 2017 Участник Central Washington University, Team S1-G2, Pengilly Fall 2017
CWU-PENGILLY-F17S1G2
4 членов
Автор 4 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 10
За последние 30 дней: 50
За всё время: 3,029
