Введение
Looking for a guide to help you replace your MSI GP60 2PE Leopard hard drive? This is the guide for you. Simply follow a few steps and your hard drive will be out in no time.
Выберете то, что вам нужно
Find the unlock tab located on the upper right side of the device, then slide it to the right.
Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
Remove the two 5 mm black screws on the right hand side with a Phillips #0 screwdriver.
Lift the hard drive, then remove from the device. There is a black strip of plastic attached to make the process easier.
3 участников успешно повторили данное руководство.
