Введение
The process to replace the battery involves a few steps. The first step is unscrewing the 15 screws that hold the bottom plate together to gain access to the battery. The second step is unplugging the battery carefully to be replaced.
Выберете то, что вам нужно
Remove the eleven 5mm screws with a Phillips #0 bit.
Remove the four 2.5mm screws with a Phillips #0 bit.
Unplug the battery connection carefully from the motherboard, and remove the old battery.
5 участников успешно повторили данное руководство.
Один комментарий
The screws on corners doesnt have the same length. The Guide is wrong carefull!
