Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the eleven 5mm screws with a Phillips #0 bit.
Remove the four 2.5mm screws with a Phillips #0 bit.
After opening the bottom plate, locate the battery and the battery connection.
Unplug the battery connection carefully from the motherboard, and remove the old battery.
Gently lift the selected black tab that connects the cable onto the board and then slide out the cable.
Gently remove the electronic component by sliding it out and lifting it up after unscrewing the 2.5 mm screw
After unplugging all of the cables and unscrewing all of the screws, gently remove the motherboard out of the computer chassis
This part will take some effort but remember not to apply to much pressure on the motherboard as to not damage any of the small electrical components on the board
2 участников успешно повторили данное руководство.
2 Комментариев
Hello,
can you please submit us the mainboard version (V1.1 or V1.2) for the MSI GS60 Ghost Pro 4K Laptop?
i need a replacement but i dont know which version is the right one for my GS60 4K (MS-16H71)
thanks in advance
best regards
Hi,
Hi,
I was wondering if you could help me? I need to find a complete bottom section for my MSI GS60 2QEAs it has completely melted. If you could let me know of any possible suppliers I’ll be very grateful.
