MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement
Выберете то, что вам нужно
  1. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Place this device back panel facing up.
  2. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: шаг 2, изображение 1 из 1
    • Using the screwdriver, unscrew the highlighted 1.2mm Phillips head #0 screws which secure the back panel into place.
  3. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: шаг 3, изображение 1 из 2 MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: шаг 3, изображение 2 из 2
    • Using the plastic opening tools, separate the back panel from the rest of the device.
    • Do this by firmly pressing the head of the tool into the space between the back panel, and the rest of the device.
  4. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, Battery: шаг 4, изображение 1 из 1
    • Pull the back panel off.
  5. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: шаг 5, изображение 1 из 1
    • Notice the L-shaped battery in the lower right corner of the opened laptop.
    • Disconnect the battery from the slot it is connected to. You'll need to push on the sides of the clip and pull.
  6. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: шаг 6, изображение 1 из 2 MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: шаг 6, изображение 2 из 2
    • Lift up the battery with your fingers and remove it from the laptop.
    • Place the battery away from the laptop in a safe spot and insert your new battery by hooking it up to the slot you previously disconnected the old battery from.
  7. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, MotherBoard: шаг 7, изображение 1 из 1
    • Unscrew the 4 1.2mm Phillips #0 screws connecting the motherboard to the laptop case.
    • Disconnect the wires connecting to the motherboard to the USB ports.
    • Disconnect the ribbon cables connecting the keyboard, and track pad of the device.
  8. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: шаг 8, изображение 1 из 1
    • Lift the motherboard up and out of the device casing.
  9. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement, RAM Cards: шаг 9, изображение 1 из 1
    • Lift the motherboard around.
    • You'll notice the RAM cards located where the red box is shown.
  10. MSI GS60 Ghost Pro 4K Gold Edition RAM Cards Replacement: шаг 10, изображение 1 из 1
    • Pull the silver latches to release the RAM cards.
    • Pull out the cards and replace them with new ones.
Заключение
Stephen Felix
Участник с: 10/20/17
207 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team S2-G2, Julie Fall 2017 Участник UMass Dartmouth, Team S2-G2, Julie Fall 2017
UMASSD-JULIE-F17S2G2
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 9
За всё время: 512
