MSI GS63VR 7RF Stealth Pro Battery Replacement
Выберете то, что вам нужно
  1. MSI GS63VR 7RF Stealth Pro Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Use the spudger to separate the back plate from the rest of the computer with the screen up like in the picture.
    • Once the back plate is loose, close the screen for an easier time properly removing it.
  2. MSI GS63VR 7RF Stealth Pro Battery Replacement: шаг 2, изображение 1 из 1
    • Using a Phillips Head #1 screwdriver, unscrew the 15 screws on the bottom of the device
    • After all the screws are unscrewed, remove the bottom plate. If this is the first time that you are removing this back cover, the last screw is hidden under the "factory seal" label. You will need to break that label to reach that screw.
    • Keep track of all the screws and which slot they came from, as they slightly differ. We recommend this system: lay out on a piece of paper and pretending the paper is the device. Place the screws on the paper approximately where they would go.
    • Another method for keeping track of all the screws would be to secure each removed screw near the hole that it was removed from with a piece of painters or masking tape. This type of tape is easy to remove from the fuzzy surface but strong enough to secure the screw to the back cover.
  3. MSI GS63VR 7RF Stealth Pro Battery Replacement: шаг 3, изображение 1 из 3 MSI GS63VR 7RF Stealth Pro Battery Replacement: шаг 3, изображение 2 из 3 MSI GS63VR 7RF Stealth Pro Battery Replacement: шаг 3, изображение 3 из 3
    • Locate the battery.
    • Wedge the spudger underneath the battery, and apply pressure to lift it away from the rest of the device.
    • Gently pull and wiggle the multiple colored wired connector out from the socket.
    • If you are removing the original battery, the back has a couple foam strips that were installed for cushioning. Those can be carefully removed and placed on the new replacement battery, but it is not necessary.
Заключение
9 участников успешно повторили данное руководство.
Chris Gifford
Участник с: 10/20/17
980 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team S2-G1, Julie Fall 2017 Участник UMass Dartmouth, Team S2-G1, Julie Fall 2017
UMASSD-JULIE-F17S2G1
3 членов
Автор 5 руководств
Один комментарий
Please note, everyone that is replacing. Please replace this with this type of battery model: BTY-M6J. Or else your battery may get damage.
Alexander Eap - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 17
За последние 30 дней: 57
За всё время: 23,111
