Введение
Over time, nearly every battery is going to need to be replaced. Is it time to replace yours? This is how you can do that.
Выберете то, что вам нужно
Use the spudger to separate the back plate from the rest of the computer with the screen up like in the picture.
Once the back plate is loose, close the screen for an easier time properly removing it.
Using a Phillips Head #1 screwdriver, unscrew the 15 screws on the bottom of the device
After all the screws are unscrewed, remove the bottom plate. If this is the first time that you are removing this back cover, the last screw is hidden under the "factory seal" label. You will need to break that label to reach that screw.
Locate the battery.
Wedge the spudger underneath the battery, and apply pressure to lift it away from the rest of the device.
Gently pull and wiggle the multiple colored wired connector out from the socket.
9 участников успешно повторили данное руководство.
Один комментарий
Please note, everyone that is replacing. Please replace this with this type of battery model: BTY-M6J. Or else your battery may get damage.
