Выберете то, что вам нужно
Remove the 6 screws on the bottom plate of the laptop using a Phillips driver.
Insert the plastic opening tool into the back plate of the laptop and lightly pry it up.
Slide the plastic opening tool around the laptop's edge gently, slowly popping off the clips securing it into the laptop.
Remove the back plate.
Locate the battery.
Remove the tape covering the battery connector.
Place your hands at the corners of the wires.
Pull upward from the back end of the battery where the wires are located.
Remove the battery.
